ptmcdonald
Nov 08, 2021Aspirant
ReadyNAS 424 Virus Updates Fail
I am having the same problem others have reported... "Antivirus scanner definition file update failed due to download failure. Check your Internet connection." This problem started a couple weeks a...
- Nov 08, 2021
Didn't you see the solution (posted several times now)?
Update to 6.10.6: https://kb.netgear.com/000064345/ReadyNAS-OS-6-Software-Version-6-10-6
Nov 08, 2021Guru - Experienced User
ptmcdonald
No I didn't but I will give that a try. Of course, it begs the question why the system didn't automatically update it's own firmware since I have it configured to do that. Apparently "automatic update" doesn't mean what I thought it did. :) Thanks for your help!
- StephenBNov 08, 2021Guru - Experienced User
ptmcdonald wrote:
Of course, it begs the question why the system didn't automatically update its own firmware since I have it configured to do that. Apparently "automatic update" doesn't mean what I thought it did.
Netgear's release process starts by posting the release notes and the binaries, allowing people who want the release immediately to manually install. After a week or so, they put it on the update servers.
So if you simply wait a bit longer, you should get the update automatically.
- ptmcdonaldNov 08, 2021Aspirant
StephenB wrote:
ptmcdonald wrote:Of course, it begs the question why the system didn't automatically update its own firmware since I have it configured to do that. Apparently "automatic update" doesn't mean what I thought it did.
I hear that. I would have thought that a security issue would merit an immediate hotfix rather than slomo easy as you go... ;) I had deliberately waited a few days before posting to see if an automated update would cure it. The manual update did the trick. Thanks again!- SandsharkNov 08, 2021Sensei
Completely replacing the AV software is beyond what should be (and likely can be) installed as a hotfix, over which the user has no control.
FWIW, I consider AV on a NAS to be unnecesary. Everything that gets onto my NAS does so via a computer that has superior AV installed. So to say an AV update is "critical" is questionable.
