carlpea
Oct 27, 2024Tutor
ReadyNAS 426 - Failed drive ok after re-insert and RAID rebuild
Hi All, Had an odd occurance this weekend where one drive was reported as 'Failed', however after pulling the drive and re-inserting the array fully rebuilt (24 hours +) and the drive shows as no...
Oct 27, 2024Guru - Experienced User
Download the full log zip file, and look in there for disk and btrfs errors.
After you have the logs, perhaps run the disk test from the volume settings wheel.
