ngcla's avatar
ngcla
Old Readynas Duo does not power up after re-inserting original drive
I have an old ReadyNAS Duo RND2150 with a single Seagate 500G HDD (S/N: 1VB385RV000BA) probably with the latest firmware and RaidDar.
I have been using 2x WD Black 2TB in x-RAID for about 6 months without any problem.  After I took the 2 drives out and re-inserted the original 500G HDD into the unit and pressed the power button, it blinked 2 to 3 times and then cut off, giving out a burning smell at the back.  The rear of the chassis was very warm to the touch.  I pulled the power cord and waited for a minute.  Took the drive out and found that one of the diodes near its SATA power connector had burnt out.  Pressed the power button again with no drive in the unit.  The power button blinked once and nothing happened.  The fan did not start either.  Again the rear end got very warm so I unplugged it straight away.  PSU output was 12.2V which appeared normal.  I suspected that the circuit board of the unit had been fried by the defective Seagate HDD.
Please help me urgently:
1.  I wish to repair the unit as it is so reliable.  Can I get Netgear Australia to replace the circuit board?  Or I can buy it and replace it myself if available.
2.  I heard that I needed to update the new circuit board to the same firmware I was in before it would recognise the 2x WD 2TB drives.  True?  How can I ascertain their firmware version if I cannot turn on the unit?
3.  If I buy a new ReadyNAS 102 (diskless unit), how can I make it use the 2x WD drives and see my files again?
PS. Ironically, when I removed the burnt diode on the Seagate drive, the drive was working and recognised by Minitool Partition Wizard but my ReadyNAS duo is dead!
  • Hi ngcla,
    We appreciate your feedback and for letting us know that the information we provided has helped resolve your issue. If your issue is now resolved, we encourage you to mark this thread resolved by clicking the “Accepted as Solution” button in one of the responses that you received. We hope that you will be an active member of the community and be a helpful resource in the future.
    Kind regards,
    BrianL
    NETGEAR Community Team
    • ngcla's avatar
      ngcla
      mdgm wrote:
      If you get the 102 please see ReadyNAS: Migrating disks from RAIDiator to OS 6
      I may not be buying the 102 just yet.  I am bidding for a second hand RND2150 (same model) on ebay.  That may make the migration of the 2x WD 2TB X-Raid drives easier.  Yesterday, I searched the web for any software that can backup the contents of the WD drives in the meantime.  I found that R-Linus (a freeware) is the only one that can reproduce the same directory tree and file names in the drive.  So I will do a backup asap.
      I tried to ring up Netgear Australia yesterday but I was always put to a voice mail.  Can I actually order the circuit board from Australia or the US?
ProSupport for Business
