wifiblues's avatar
wifiblues
Luminary
Jul 09, 2020
original password
i am upgrading my orbi router and sattelite to RBK43.  I purchased a used Orbi from a friend.
how do i reset the wifi password back to the Orbi given one?
thanks.
wifiblues
  • I would use a wired PC and web browser to walk thru the setup wizard.
  • FURRYe38's avatar
    Press the reset button in back for 15 seconds then release. Wire connect up a PC and walk thru the setup wizard.
    • wifiblues's avatar
      wifiblues
      Luminary
      thanks - and do the same function for the satellites?
      • FURRYe38's avatar
        No, but you can if yon want to. The login info and pw will be confgured automatically on the RBS once it's synced to the RBR.
