ngcla
Apr 24, 2016Aspirant
Old Readynas Duo does not power up after re-inserting original drive
I have an old ReadyNAS Duo RND2150 with a single Seagate 500G HDD (S/N: 1VB385RV000BA) probably with the latest firmware and RaidDar. I have been using 2x WD Black 2TB in x-RAID for about 6 month...
- May 02, 2016
Hi ngcla,
We appreciate your feedback and for letting us know that the information we provided has helped resolve your issue. If your issue is now resolved, we encourage you to mark this thread resolved by clicking the “Accepted as Solution” button in one of the responses that you received. We hope that you will be an active member of the community and be a helpful resource in the future.
Kind regards,
BrianL
NETGEAR Community Team
mdgm-ntgr
Apr 26, 2016NETGEAR Employee Retired
If you get the 102 please see ReadyNAS: Migrating disks from RAIDiator to OS 6
- ngclaApr 26, 2016Aspirant
mdgm wrote:If you get the 102 please see ReadyNAS: Migrating disks from RAIDiator to OS 6
I may not be buying the 102 just yet. I am bidding for a second hand RND2150 (same model) on ebay. That may make the migration of the 2x WD 2TB X-Raid drives easier. Yesterday, I searched the web for any software that can backup the contents of the WD drives in the meantime. I found that R-Linus (a freeware) is the only one that can reproduce the same directory tree and file names in the drive. So I will do a backup asap.I tried to ring up Netgear Australia yesterday but I was always put to a voice mail. Can I actually order the circuit board from Australia or the US?
- mdgm-ntgrApr 26, 2016NETGEAR Employee Retired
We don't sell replacement motherboards.
Also support is for the original purchaser from an authorised reseller. There will be no NETGEAR support for a unit you purchased off eBay.
You do need to make sure that the Duo you are bidding for is also a v1. See http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
The v2 is a very different product and you can't move your disks to that.- StephenBApr 27, 2016Guru - Experienced User
Linux Reader is also free, and can read the contents of the duo's data disk. http://www.diskinternals.com/linux-reader/
