Supercows
Dec 22, 2020Guide
ReadyNAS 426 memory upgrade (it is possible!)
Hi,
I just succesfully added a extra dim in my RN426 readynas. I have opend the black cover and remove the 4 black screws from the metal frame and you can get to the mainboard :) You can slide this side open. I saw 4 memory slots. I have added the same memory that was already in it from Transcend the TS512MLH64V1H. I paid 39,- euro's in Holland but you can get it for arround 26,- here also.
/home/admin# dmidecode -t 17
# dmidecode 2.12
SMBIOS 3.0 present.
# SMBIOS implementations newer than version 2.8 are not
# fully supported by this version of dmidecode.
Handle 0x002A, DMI type 17, 40 bytes
Memory Device
Array Handle: 0x0028
Error Information Handle: Not Provided
Total Width: 8 bits
Data Width: 8 bits
Form Factor: DIMM
Set: None
Locator: DIMM0
Bank Locator: BANK 0
Type: <OUT OF SPEC>
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 2133 MHz
Manufacturer: Transcend
Serial Number: 0014F7DB
Asset Tag: BANK 0 DIMM0 AssetTag
Part Number: TS512MLH64V1H
Rank: 1
Configured Clock Speed: 2133 MHz
Minimum voltage: 1.200 V
Maximum voltage: 1.200 V
Configured voltage: 1.200 V
Handle 0x002C, DMI type 17, 40 bytes
Memory Device
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: DIMM
Set: None
Locator: DIMM0
Bank Locator: BANK 1
Type: Unknown
Type Detail: Unknown
Speed: Unknown
Manufacturer: NO DIMM
Serial Number: NO DIMM
Asset Tag: NO DIMM
Part Number: NO DIMM
Rank: Unknown
Configured Clock Speed: Unknown
Minimum voltage: Unknown
Maximum voltage: Unknown
Configured voltage: Unknown
Handle 0x002D, DMI type 17, 40 bytes
Memory Device
Total Width: 8 bits
Data Width: 8 bits
Form Factor: DIMM
Set: None
Locator: DIMM1
Type: <OUT OF SPEC>
Speed: 2133 MHz
Serial Number: 00000005
Asset Tag: BANK 0 DIMM1 AssetTag
Rank: 1
Handle 0x002F, DMI type 17, 40 bytes
Memory Device
Data Width: Unknown
Form Factor: DIMM
Set: None
Locator: DIMM1
Type: Unknown
Speed: Unknown
Asset Tag: NO DIMM
Rank: Unknown
:/home/admin# cat /proc/meminfo
MemTotal: 8124648 kB
MemFree: 4838652 kB
MemAvailable: 6187940 kB
Buffers: 2388 kB
Cached: 1834552 kB
I a saw a topic earlier saying it was possible and it is :)
