Dwrws
May 17, 2024Aspirant
ReadyNAS 4312 Not pinging
I have readynas 4312 i am not able to ping the NAS also not able to find the NAS on Raidar software
May 18, 2024Guru - Experienced User
What happens if you power down, remove the disks, and power up again?
Normally when you do that, you would be able to ping the NAS, and RAIDar would find it with a no disks status.
Label the disks by slot as you remove them, so you can easily restore them to the same slot after this test. Make sure the NAS is powered down when you put them back.
- DwrwsMay 18, 2024Aspirant
all disks are removed and power up the NAS but still the same problem, NAS is not pinging. Raidar also not finding the NAS
- StephenBMay 18, 2024Guru - Experienced User
What is the ethernet LED status?
Have you tried a different ethernet port on the NAS?
- DwrwsMay 18, 2024AspirantTried all 4 ports but problem is same.
In ethernet port only 1 green LED is glowing.
