mariasuresh
Apr 25, 2022Follower
Readynas 4312
Dear sir, Previously used only 8bays for HDD NOW ADDING 4HDD WE ARE INSERT HDD BUT NOT WORKING PROPERLY. so Please shortout the issue.
Apr 26, 2022Guru - Experienced User
We'll need a lot more information than that.
- what firmware you are running?
- what RAID mode are you using?
- what drive models are you adding?
- whether the new drives are formated
- whether you tested them before insertion.
Sandshark
Apr 26, 2022Sensei
Also need a better description of "not working correctly". Do you see the drives in the GUI but they are not added to the volume, or don't see them at all? Is there a chance somebody purchased SAS drives instead of SATA? The 4312 looks like a common server, most of which accept SAS drives, and the slots in it will also accept SAS physically. But the 4312 does not contain a SAS controller, so they won't work.
