knorman5
Dec 13, 2021Aspirant
readynas 4360 how to replace a drive that was removed by the NAS
I have a redynas 4360. flly loaded. that apparently removed a drive from slot 39 of the 3rd raid volume so. I inserted a compatible drive from another system. when i insert the new drive the drive next to it (38) was revoved and i got an error saying to remove several others to us the new drive? so i put the old drive back in slot 39 the raid array is resyncing. Problem is its reporting errors and SLot 38 is Still missing. even though it is physically present. ??? how do replace drive 39 that is complaining of reallocation errors , and get drive 38 Back!
Did you unformat it first? If it was from another ReadyNAS, the system might have gotten confused.
Not sure what to make of the issue with slot 38, but the best solution for slot 39 is to hot-insert a blank (unformatted) disk. Alternatively, format it as NTFS. Then hot-insert it, and format it again from the NAS volume page.
- knorman5Aspirant
OK, after sync is complete. reformat the drive externally (NTFS) , pull the failing drive from slot 39, Insert the newly re-formated drive in its place. Will the NAS prompt me to format the drive?
After the volume re-syncs i think i will reseat the drive in slot 38? is that a safe plan?
Note: this replacement drive was previously part of a raid 6 array on a synology NAS that died. it is the same drive as we have in the readynas.
No, the NAS won't prompt you. You'll need to select it and format it.
Though if you are formatting with Windows, you can just delete the partitions with Windows Disk Manager instead. Then just hot-insert the drive. Then there is no need to reformat on the NAS.
That is reasonable, and should be safe.
You could look in the logs first - you should see an entry for the removal when it became unseated.
