marioscimone's avatar
marioscimone
Readynas 516 6x4Tb
I'm new, I have the readynas 516 with OS 6.9.5 equipped with 6x4Tb Wd4001FAEX, connected with one of the network card to a gigabit switch. On the same switch I have a dell laptop I7 with 8Gb ram an...
  • StephenB's avatar
    Apr 13, 2019
    The first thing to do is confirm that the connections are actually negotiating gigabit - since your speeds are consistent with 100 mbit ethernet. You can see the speed on the network page of the ReadyNAS web ui (or in network_settings.log in the zip file).  You should also confirm it on the dell.
    Cabling is one potential cause of your problem.  So you could try different cables on both connections.  Cat-5e or better is what you should be using.
    NasTester is a convenient way to measure speeds (and has the advantage that people here can compare their results with yours).  http://www.808.dk/?code-csharp-nas-performance
ProSupport for Business
