Maxpower411
Apr 22, 2021Aspirant
ReadyNas 516 and My Future
ReadyNas 516 Latest Firmware, 5- 12TB drives (with the #2 Drive Removed, for Command Timeout Issues- I have recently spent a lot of time, working with my old ReadyNas 516. First it had a disk failur...
- Apr 24, 2021
I'm glad you got through it.
Apr 22, 2021Guru - Experienced User
Maxpower411 wrote:
2021-04-21 10:26:33: Assertion 'f->data_hash_table' failed at ../src/journal/journal-file.c:1047, function journal_file_link_data(). Aborting.
I've seen this error posted here twice before. In both cases it was a full root volume. Is the web ui giving you any indication of that? Did you install any apps after the reset?
If it is a full root, then it should be fixable without more expense. One option (painful) is to do yet another reset.
Maxpower411 wrote:
My Fix will be the purchase of a Netgear ReadyNas 626X 6 Bay Diskless, this seems available for about $1200
A few months back they were available for $900-$1000, but they were $1200 or more back early 2019. Supply has been limited (and there has been some speculation that Netgear is exiting the NAS business). FWIW, I have no information on that.
Anyway, the price is a somewhat high, but not crazy. Not sure where you are located, but there is one I see at the $1000 price point here: https://bluesquarepower.com/netgear-readynas-626x-6-bay-rn626x00-100nes.html
There are a couple of RN42x systems out there that are around $600 (they are gigabit only).
- https://bluesquarepower.com/netgear-readynas-428-8-bay-rn428.html
- https://www.disctech.com/Netgear-ReadyNAS-426-RN42600-100NES-6-Bay-NAS-Array
- Maxpower411Apr 22, 2021Aspirant
Stephen- Thanks for the quick reply, I did see the one for $1050, (Blue Square Power) but tried to look them up, on the netgear authorized resellers list, but could not find them. (they claim they are, but I have found people lie) I feel the 5 year warranty is important, and want to make sure they are legit. The CDW, was the $1200.00 price, they say,it should be in stock by the 9th, I am sure they are authorized Netgear Dealers.
As far as the 516 goes, I have no problem, doing another factory reset, as there is no data in it, or expectations- I think I might have done it twice, but will try again, the resysc is so slow- I couldn't care less. I figure with the Factory reset it blanks all drives, and starts as new, maybe there is an issue, with the bad bus, causing this errror. (but I will give it another shot)
Has anyone bought anything such as a ready NAS from Blue Square Power listed in the earlier link?
Lastly, I feel that I would rather goto the 626, than the RN4 series, as most all of that is EOL, and if Netgear quits making the NAS,I would rather have a Later Netgear than one of these non Netgear out there.
I spent about a week looking, and the (Blue Square Power/CDW were the only sellers out there, I could find.($1200 or less for a new Netgear NAS)
Thanks again-
Jeff
- StephenBApr 22, 2021Guru - Experienced User
Just to clarify this: The RN520 and RN620 series were launched in 2016; the RN420 series were launched in 2017. So the RN420 series is a year newer than the RN620.
The RN626 does have some advantages - it supports 10 gigabit ethernet, and has server-grade (error correcting) RAM.
JohnCM_S , Marc_V : is something you can check? They aren't on this list: https://www.downloads.netgear.com/files/GDC/NETGEAR_Authorized_Resellers.pdf But I don't know if it is up do date.
- mdgmApr 22, 2021Virtuoso
I have both the 516 and the 626X. The 626X is a nice upgrade from the 516. The only thing I miss from the 516 is the HDMI port (which probably doesn't matter too much to most users anyway).
The quad-core CPU in the 620 series and 10GBASE-T are great.
The 520 series replaced the 516 and the 620 series replaced the 716X.
The 420 series replaced the 300 series and is the lower end of the desktop ReadyNAS that have Intel CPUs.
