m1sterd
Apr 18, 2013Tutor
ReadyNAS 516 feature questions
Hi All, I am considering purchasing a ReadyNAS RN51600 diskless NAS drive, I shall be using it to primarily hold my video and photo collections and for running Plex to allow serving these vIdeos/ph...
super_poussin
Apr 25, 2013Virtuoso
JabbaTheHutt wrote: 1. There is not a VPN server app available from the Genie+ marketplace list of apps yet. There are hundreds of developers signed up though and the application list should grow quickly. You can install the app through the command line via SSH. Take some technical knowledge to do, but the ReadyNAS is not locked down in any way.
2. Plex Server is available on the current ReadyNAS 300 and 500 series products. Plex Server is still in the works for the 100 series. HDMI is not supported yet.
3. There is no development/virtual image of the ReadyNAS available for developers. There is an SDK that is made available to developers through the Genie+ infrastructure. Find out more information at developer.netgear.com
A VPN Server addon is ready and is under Netgear revue, I use it since 1 month without problem it works with iphone, ipad, macos X ....
