m1sterd
Apr 18, 2013Tutor
ReadyNAS 516 feature questions
Hi All, I am considering purchasing a ReadyNAS RN51600 diskless NAS drive, I shall be using it to primarily hold my video and photo collections and for running Plex to allow serving these vIdeos/ph...
chirpa
Apr 26, 2013Luminary
If you plug in HDMI, you can see the BIOS post message as the system boots. If someone installs XBMC and required X windows, should be able to output media via the HDMI. This is likely the plan NTGR will target eventually with it.
Regarding the SDK, see: viewtopic.php?p=392569#p392569
