m1sterd
Apr 18, 2013Tutor
ReadyNAS 516 feature questions
Hi All, I am considering purchasing a ReadyNAS RN51600 diskless NAS drive, I shall be using it to primarily hold my video and photo collections and for running Plex to allow serving these vIdeos/ph...
m1sterd
May 19, 2013Tutor
Hi super-poussin, I followed the above and can indeed see the VPN Server displayed int he installed apps, it even says it is running, however the Launch button is still greyed out, you mention go to the vpnserver Share to get the management console, but I am not sure what you mean by this?
Also I notice now in the Accounts -> Users that a new mysql user has appeared, was this configured and mysql installed as part of the vpnserver? If so if I want to remove it using the remove link on the application page, will it also remove all the dependancies that were installed? (I am not saying I will remove it, but it would be good to know). NOTE: I did also install piwigo, could this have added the mysql group and user accounts?.
Update: Ok I went to the site for the software provider, what you are saying is that it doesn't have a web interface, instead you use the GUI tools the company provides to administer the VPN server. I couldn't find a Mac version of the configuration utility though, is it Windows only?.
