Rottenweiler's avatar
Mar 01, 2023
ReadyNAS 516 Power Supply
Looking to buy a Power Supply for a ReadyNAS 516.
Anyone have a source/link they can share?
Anyone selling a chassis for parts? Spares?
Need a front door (LCD actually) for a RN316.
Also need a SINGLE metal/plastic foot for a RN316 (No idea how it went missing)
Yes, I have been watching on eBay for months, no luck.
Send me a note if you have parts to sell.
Thanks, Patrick
1 Reply
  • Easy to find compatible feet on eBay.  The supply is a Flex ATX (aka mini ITX) one, but with a slightly modified connector pin-out (same pin-out as legacy units that use that form factor).  AFAIK, the 316 and 516 doors are interchangeable.  The back/bottom chassis sections do differ, and I never looked at the SATA backplanes close enough to see if they differ.  The power supplies definitely are the same.  So a single 316 or 516 parts unit should fill both needs, assuming the problem isn't with the power supply or display.  Netgear has never sold parts.
ProSupport for Business
