johndbiggs
May 10, 2023Aspirant
ReadyNAS 542X can't install applications
I had to do a full reset of my ReadyNAS 542X and I can't install applications anymore. I've changed the DNS, set a static IP, and attempted uploading deb files. Can anyone advise me on next steps?
mathiourose
Nov 12, 2023Aspirant
Hi I have one RN314 and 2 RN316 (in different locations) - none of them can install apps (I haven't tried to for a while). I tried uTorrent, iDrive, Drupal - but they all crash the UI and I have to log on again.
I installed the new firmware 6.10.9 on one of them to test - but the same issue happens.
I have not reinstalled OS as I dont want to chance losing an important app I use (Zero Tier One).
Help appreciated - if anyone suggests SSH - I have never used it, so need really idiot-proof instructions.....
Thanks in advance.
J Rose
- StephenBNov 12, 2023Guru - Experienced User
There are patches needed for most installations to work, due to the archival/deprecation of Debian 8 ("Jessie").
Post 37 in the attached thread has the two files you need.
Post 4 in this thread gives you some instructions on how to install these patches w/o needing to know ssh commands:
- SandsharkNov 13, 2023Sensei
Actually, I believe you still have to issue the apt-get update command from SSH.
- mathiouroseNov 13, 2023Aspirant
Thanks - how do I do this? Im far from an expert with SSH....
