johndbiggs
May 10, 2023Aspirant
ReadyNAS 542X can't install applications
I had to do a full reset of my ReadyNAS 542X and I can't install applications anymore. I've changed the DNS, set a static IP, and attempted uploading deb files. Can anyone advise me on next steps?
Nov 12, 2023Guru - Experienced User
There are patches needed for most installations to work, due to the archival/deprecation of Debian 8 ("Jessie").
Post 37 in the attached thread has the two files you need.
Post 4 in this thread gives you some instructions on how to install these patches w/o needing to know ssh commands:
Sandshark
Nov 13, 2023Sensei
Actually, I believe you still have to issue the apt-get update command from SSH.
- mathiouroseNov 13, 2023Aspirant
Thanks - how do I do this? Im far from an expert with SSH....
- SandsharkNov 13, 2023Sensei
You go to SSH and issue that command. If you are on Windows, you can go to SSH (assuming you've enabled it on the NAS) with ssh root@xxx.xxx.xxx.xxx from a command prompt where xxx.xxx.xxx.xxx is the IP address for your NAS. The login password is the same as your admin password for the NAS.
Thanks for your patience.
Done and heres what I got back via windows command.com
Rebooted NAS - still no joy for iDrive or Drupal.
A lot of errors/ignores below.
Im running parallels on a mac - so will try with a pure windows pc.
J
Welcome to ReadyNASOS 6.10.9
root@NAS-316:~# apt-get update
Ign:1 http://security.debian.org jessie/updates InRelease
Ign:2 http://security.debian.org jessie/updates Release
Ign:3 http://security.debian.org jessie/updates/main amd64 Packages.diff/Index
Ign:5 http://security.debian.org jessie/updates/main all Packages
Ign:6 http://security.debian.org jessie/updates/main amd64 Packages
Ign:4 http://mirrors.edge.kernel.org/debian jessie InRelease
Ign:7 http://mirrors.edge.kernel.org/debian jessie Release
Err:6 http://security.debian.org jessie/updates/main amd64 Packages
404 Not Found [IP: 146.75.118.132 80]
Ign:8 http://mirrors.edge.kernel.org/debian jessie/main amd64 Packages.diff/Index
Ign:9 http://mirrors.edge.kernel.org/debian jessie/main all Packages
Ign:10 http://mirrors.edge.kernel.org/debian jessie/main amd64 Packages
Err:10 http://mirrors.edge.kernel.org/debian jessie/main amd64 Packages
404 Not Found [IP: 147.75.80.249 80]
Hit:11 https://apt.readynas.com/packages/readynasos 6.10.9 InRelease
Reading package lists... Done
W: The repository 'http://security.debian.org jessie/updates Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'http://mirrors.kernel.org/debian jessie Release' does not have a Release file.
E: Failed to fetch http://security.debian.org/dists/jessie/updates/main/binary-amd64/Packages 404 Not Found [IP: 146.75.118.132 80]
E: Failed to fetch http://mirrors.edge.kernel.org/debian/dists/jessie/main/binary-amd64/Packages 404 Not Found [IP: 147.75.80.249 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
root@NAS-316:~#
