mrQQ's avatar
mrQQ
Apprentice
Apr 11, 2020
ReadyNAS 6.10.3 OneDrive bidirectional sync problem
Hello,   I have RNDU6000 running 6.10.3. I enabled bidirectional sync to OneDrive and found this issue:   * when I delete a file in OneDrive, it is deleted in NAS * when I delete a file in NAS, ...
  • JohnCM_S's avatar
    JohnCM_S
    Aug 06, 2020
    Hi poko2121,
    It will be best for you to contact our support team. There is a fix that they can apply to your NAS that can probably fix the issue.
ProSupport for Business
