funglenn
Mar 19, 2020Luminary
Readynas 6.9.6 update killed php
can anyone tell me exactly what this latest update does, i know it fixes: Fixed Microsoft OneDrive authentication issue Updated Gmail notifications to follow Google's security requirements bu...
- Mar 20, 2020
Stephen,
thanks for the idea, i will keep rnxtras.com in mind for future hiccups. However, when i went back to troubleshoot the system--it was all working just fine! i am very puzzled but happy that it works. But I am going to take some time to look at versions and insure everything is working well.
Mar 19, 2020Guru - Experienced User
What were you running before you updated?
There have been some cases where apache updates have broken PHP before - though I don't recall if 6.9.6 was one of those. You could try installing the php package offered by WhoCares_ at rnxtras.com and see if that works.
