Mark_53's avatar
Dec 06, 2017
R6700 Firmware update kills router
I tried to update per the insturctions sent 12/1/2017.R6700-V1.0.1.36_10.0.40
except I did it over a wireless connection and now I cannot communicate to the router even when directly connected through ethernet.   Help
  • After trying a TFTP update with a Netgear Support agent, I was given an RMA to return the unit which I did.  That should solve the problem.
  • I tried to press the factory reset button in the back of the unit for 7 seconds but nothing happens.  Is there some indication that the factory rest was completed?
      • Mark_53's avatar
        Mark_53
        Star
        Thanks for the help.  The power button is blinking white.  User manuel says that means firmware is corupt and to contact tech support.  Is this tech support?  What next?
  • Hi Dear
    my netgear router R6700 is killed after apply your last update .... im so confused and dont understand why?  the update is FAKE from Netgear or how?
    can you gelp me to recover it
    Best Regards
    Patrick
  • The latest update has made my R6700 router unreliable wifi wise, any cure available?
    • RegisterAgain's avatar
      RegisterAgain
      I solved my problem by removing this *** and reinstalling my ten year old Apple Time Capsule; fast. dependable internet again. Netgear can take a hike!
      • d0x's avatar
        d0x
        Guide
        Frustration is certainly understandable but that router you are using has its own security vulnerabilities and it's a product apple doesn't provide security updates for.
        You would be better served buying a $40 router that is current than you would using an old one. Routers, at least consumer ones are notorious for security holes.
        Whatever you decide to do just remember that updating via WiFi is always not advised.
        That said since your device was bricked by what seems like a bad rom chip I'd call Netgear on the phone and demand replacement and I wouldn't stop until it was replaced. I'd file a complaint with the BBB and my State AG along with maybe even the FTC. Such an expensive router shouldn't die so quickly unless it was abused. It just shouldn't.
        Also for future reference keep in mind routers tend to run hot so give them proper air circulation and blow any dust out of them. Heat kills.
