Clammy
Apr 18, 2018Guide
ReadyNAS 6 cpu specs
Hello, I have various ReadyNAS 6 Pro models and I can't find the CPU specs. I remember there used to be a spreadsheet that Netgear had with all the models and their specs. These are older disco...
Clammy
Apr 18, 2018Guide
Hi John,
Do you know exactly which CPU model they came with?
I also have an RNDP6000. Does that have the same CPU or the atom version?
Thank you!
JohnCM_S
Apr 18, 2018NETGEAR Employee Retired
Hi Clammy,
The RNDP6000-100 uses the E2160 1.8Ghz while the RNDP6000-200 uses the E5300 2.6GHz. Both NAS models use Pentium CPUs. You can also check the CPU model on the NAS system logs.
- ClammyApr 18, 2018Guide
The exact models that I have are:
RNDP6310-100NAS
and
ReadyNASRNDP6000v2
- StephenBApr 19, 2018Guru - Experienced User
Clammy wrote:
RNDP6310-100NAS
This one is a RNDP6000-100NAS chassis that shipped with one 3 TB disk. So it uses the E2160.
Clammy wrote:
ReadyNASRNDP6000v2
Does the part number end with -200NAS?
- mdgm-ntgrApr 19, 2018NETGEAR Employee Retired
StephenB wrote:
Clammy wrote:
RNDP6310-100NAS
Mostly correct. The RNDP6310 shipped with three 1TB disks, not one 3TB disk. 3TB disks were only starting to come onto the market when we launched the second gen Pro, the Pro 6, I think.
- JohnCM_SApr 19, 2018NETGEAR Employee Retired
Hi Clammy,
The ReadyNASRNDP6000v2 is also the RNDP6000-200 so it should have the E5300 CPU.
