LITS1337
Aug 21, 2019Aspirant
Readynas 6 drive replacement issue- volumes inactive
Had a degraded drive, which I replaced (slot 2) per the Netgear provided guides. Now I have an error stating "Remove inactive volumes to use the disk. Disk # 1,3,4,5,6" I don't see any of the da...
Aug 21, 2019Guru - Experienced User
This bit looks unusual:
Aug 21, 2019 12:27:04 PM Disk: Disk Model:WDC WD40EZRZ-00GXCB0 Serial:WD-WCC7K6ZPRCC4 was added to Channel 2 of the head unit. Aug 21, 2019 12:23:18 PM Volume: Volume data health changed from Degraded to Dead. Aug 21, 2019 12:23:16 PM Disk: Disk Model:WDC WD40PURX-64GVNY0 Serial:WD-WCC4E5JTFYZU was removed from Channel 2 of the head unit. Aug 21, 2019 01:00:41 AM Volume: Volume data is Degraded.
Are you sure you swapped the correct drive?
- LITS1337Aug 21, 2019Aspirant
Yes, it is definitely the correct drive. I found it so strange it went from degradated to dead immediately upon removal.
- StephenBAug 22, 2019Guru - Experienced User
Can you post mdstat.log (from the log zip file)?
- LITS1337Aug 22, 2019Aspirant
Here you go! thanks for the help
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md1 : active raid10 sdf2[4] sde2[3] sdd2[2] sdc2[1] sda2[0] 1305600 blocks super 1.2 512K chunks 2 near-copies [5/5] [UUUUU] md0 : active raid1 sda1[0] sdf1[5] sde1[4] sdc1[2] sdd1[6] 4190208 blocks super 1.2 [6/5] [UUU_UU] unused devices: <none> /dev/md/0: Version : 1.2 Creation Time : Wed Nov 29 15:43:23 2017 Raid Level : raid1 Array Size : 4190208 (4.00 GiB 4.29 GB) Used Dev Size : 4190208 (4.00 GiB 4.29 GB) Raid Devices : 6 Total Devices : 5 Persistence : Superblock is persistent Update Time : Thu Aug 22 09:22:33 2019 State : clean, degraded Active Devices : 5 Working Devices : 5 Failed Devices : 0 Spare Devices : 0 Consistency Policy : unknown Name : 33eaea2a:0 (local to host 33eaea2a) UUID : cc433f86:16254560:32f207b3:c217a7d2 Events : 21199 Number Major Minor RaidDevice State 0 8 1 0 active sync /dev/sda1 6 8 49 1 active sync /dev/sdd1 2 8 33 2 active sync /dev/sdc1 - 0 0 3 removed 4 8 65 4 active sync /dev/sde1 5 8 81 5 active sync /dev/sdf1
