tbrock
Nov 23, 2015Follower
ReadyNAS 600 in compatibility List?
Trying to figure out if a specific hard drive is compatible with my ReadyNAS 600 B Version. However, this version does not appear in the Hard Disk Compatibility List: http://kb.netgear.com/app/answer...
mdgm-ntgr
Nov 23, 2015NETGEAR Employee Retired
The 600 B is a Sparc ReadyNAS. The other models you mentioned are legacy x86 models.
Look at the list for the NV+ (v1). With the 600 B, like all other Sparc ReadyNAS you are limited to 2TB drives. Higher capacity disks are not compatible.
