KeithHollar's avatar
KeithHollar
ReadyNAS DUO RND2000 V2 Hard Drive Compatability List Needed
Netgear no longer seems to post a list of compatible hard drives that work with their legacy ReadyNas Duo devices. In the past, I could go to their following link at:
https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
But when I go to that link and scroll down to find a list of hard drives, I find the message below listed on the web page instead of a list of compatible hard drives. Can anyone tell me where I can obtain the needed kist.
  This content cannot be displayed in a frame
  • There's just an issue with the web site - you can't see the HCL for any model, including current ones.  You can use this link instead: https://www.readynas.com/app/hcl_disk
    BUT the HCL hasn't been updated for legacy NAS in a very long time.  So it isn't helpful if you are looking for a drive replacement.
    I recommend ignoring the HCL, and using either Western Red drives or Seagate IronWolf drives.  You could use enterprise disks also, but I don't think you'll see any performance benefit with your NAS.
  • StephenB's avatar
    • KeithHollar's avatar
      KeithHollar
      Stephen, you are awesome. Thanks so much for your super fast reply. The working link you gave to the hard drive compatability list was exactly what I needed.
ProSupport for Business
