KeithHollar
Jun 18, 2017Aspirant
ReadyNAS DUO RND2000 V2 Hard Drive Compatability List Needed
Netgear no longer seems to post a list of compatible hard drives that work with their legacy ReadyNas Duo devices. In the past, I could go to their following link at: https://kb.netgear.com/20641/Re...
- Jun 19, 2017
There's just an issue with the web site - you can't see the HCL for any model, including current ones. You can use this link instead: https://www.readynas.com/app/hcl_disk
BUT the HCL hasn't been updated for legacy NAS in a very long time. So it isn't helpful if you are looking for a drive replacement.
I recommend ignoring the HCL, and using either Western Red drives or Seagate IronWolf drives. You could use enterprise disks also, but I don't think you'll see any performance benefit with your NAS.
Jun 19, 2017Guru - Experienced User
- KeithHollarJun 19, 2017Aspirant
Stephen, you are awesome. Thanks so much for your super fast reply. The working link you gave to the hard drive compatability list was exactly what I needed.
