norbert1
Aug 18, 2014Aspirant
readyNAS 600
i want to recover files from old 600 box but when i turn in on it goes on for a second and turns off. What can I do to get it working. It was working perfectly 4-5 years ago and it was sitting in sto...
xeltros
Aug 18, 2014Apprentice
I don't know the model, so I can't say if ATX if compatible or not.
Same for using the disks in another machine, this is usually possible to boot on a linux live CD and remount the drives but I can't walk you through that for this unit as I don't know how the operating system works. Anyway, if you were to do that, it's advised to note the order of the disks to be able to put them back in the same order on the NAS.
Just to be clear, do you have important files on this ? If so you should have a backup, and I guess that after 5 years unplugged, what's on the disk is not vital...
