charley672
Aug 16, 2023Follower
ReadyNAS 615 Disk Offline
Hi everyone, I have a ReadyNAS 615 (I know, its old, but been solid) and had a drive go bad recently. I purchased a new drive and checked the SMART info on it with Seatools to make sure I received a ...
Aug 17, 2023Guru - Experienced User
Are you using FlexRaid or XRAID?
Are the files still accessible?
Is there any sign that the volume is resyncing?
- b3nny0Aug 17, 2023Aspirant
Hi StephenB, this is actually my case I posted in the /netgear sub on Reddit. I am not 100% sure which raid it is using. When I view the disks under System | Storage, it shows Raid 5+0, x2. Files are still accessible, but there doesnt seem to be anything saying the logs are syncing. When I go into the volumes and look at the summary, it shows that the Health is Degraded, but I assume that is because there is a disk not online. Below are the logs I see from when the old drive when bad until now:
Wed Aug 16 2023 17:17:25
Disk: Disk in channel '2' (Internal) changed state from UNAVAIL to OFFLINE.
Wed Aug 16 2023 17:16:23
Disk: Disk Model:ST3000NM0033-9ZM Serial:Z1ZBV2SB has been added to Channel '2' of the head unit.
Wed Aug 16 2023 17:06:04
Disk: Disk Model:ST3000NM0033 Serial:Z1Y196R9 has been removed from Channel '2' of the head unit.
Sat Aug 12 2023 10:16:57
Sat Aug 12 2023 10:16:22
System: ReadyDATAOS background service started.
Sat Aug 12 2023 10:11:40
System: System is shutting down.
Fri Aug 11 2023 22:03:20
Fri Aug 11 2023 22:02:45
Fri Aug 11 2023 22:00:19
System: The system is rebooting.
Mon Aug 7 2023 23:58:02
Disk: Disk in channel '2' (Internal) changed state from FAULTED to OFFLINE.
Mon Aug 7 2023 23:57:28
Disk: Disk in channel '2' (Internal) exceeded write error threshold (205).
Disk: Disk in channel '2' (Internal) changed state from ONLINE to FAULTED.
Mon Aug 7 2023 23:57:27
Volume: Volume 'Data' health changed from 'ONLINE' to 'DEGRADED'.Thanks for any input you might have here.
