charley672
Aug 16, 2023Follower
ReadyNAS 615 Disk Offline
Hi everyone, I have a ReadyNAS 615 (I know, its old, but been solid) and had a drive go bad recently. I purchased a new drive and checked the SMART info on it with Seatools to make sure I received a ...
Aug 17, 2023Guru - Experienced User
Are you using FlexRaid or XRAID?
Are the files still accessible?
Is there any sign that the volume is resyncing?
b3nny0
Aug 17, 2023Aspirant
Hi StephenB, this is actually my case I posted in the /netgear sub on Reddit. I am not 100% sure which raid it is using. When I view the disks under System | Storage, it shows Raid 5+0, x2. Files are still accessible, but there doesnt seem to be anything saying the logs are syncing. When I go into the volumes and look at the summary, it shows that the Health is Degraded, but I assume that is because there is a disk not online. Below are the logs I see from when the old drive when bad until now:
Wed Aug 16 2023 17:17:25
Disk: Disk in channel '2' (Internal) changed state from UNAVAIL to OFFLINE.
Wed Aug 16 2023 17:16:23
Disk: Disk Model:ST3000NM0033-9ZM Serial:Z1ZBV2SB has been added to Channel '2' of the head unit.
Wed Aug 16 2023 17:06:04
Disk: Disk Model:ST3000NM0033 Serial:Z1Y196R9 has been removed from Channel '2' of the head unit.
Sat Aug 12 2023 10:16:57
Sat Aug 12 2023 10:16:22
System: ReadyDATAOS background service started.
Sat Aug 12 2023 10:11:40
System: System is shutting down.
Fri Aug 11 2023 22:03:20
Fri Aug 11 2023 22:02:45
Fri Aug 11 2023 22:00:19
System: The system is rebooting.
Mon Aug 7 2023 23:58:02
Disk: Disk in channel '2' (Internal) changed state from FAULTED to OFFLINE.
Mon Aug 7 2023 23:57:28
Disk: Disk in channel '2' (Internal) exceeded write error threshold (205).
Disk: Disk in channel '2' (Internal) changed state from ONLINE to FAULTED.
Mon Aug 7 2023 23:57:27
Volume: Volume 'Data' health changed from 'ONLINE' to 'DEGRADED'.
Thanks for any input you might have here.
- StephenBAug 17, 2023Guru - Experienced User
b3nny0 wrote:
System: ReadyDATAOS background service started.Is this a ReadyDATA 516 (RDD516)?
Or a ReadyNAS 516 (RN51600)?
- b3nny0Aug 17, 2023Aspirant
It is a ReadyData 516 - RDD516
- schumakuAug 18, 2023Guru - Experienced User
ReadyDATA used to depend on storage blocks (HDD) signed by Netgear. This limitation was removed on the late ReadyDATA OS builds. The requirement for replacement storage blocks supporting normal 512 byte block sizes remains for HDDs and SSDs. https://kb.netgear.com/31086/ReadyDATA-OS-1-4-4-Using-unsigned-drives
