tju2
Apr 10, 2017Aspirant
Readynas 626x expansion
New Readynas 626x running 6.6.1. I started with 2 2tb drives in the default xraid config. I then added 4 4tb drives, so I now have two 2tb drives in slots 1,2, and the rest are 4tb drives. The xra...
jak0lantash
Apr 10, 2017Mentor
Did you try to reboot the NAS? It's not unheard of that a reboot helps trigger the creation of the sub RAID array on the unused capacity.
You can also download the logs from the GUI and look into systemd-journal for "expansion".
- tju2Apr 10, 2017Aspirant
Thanks for the reply! I did reboot, but I haven't looked at the logs. I'll go grab those and take a look. Thanks!
- xiao123Apr 10, 2017NETGEAR Expert
Can you download your logs and send those in (see the Sending Logs link in my sig)?Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
- tju2Apr 11, 2017Aspirant
Hey Xiao - I ended up opening a case and uploaded the logs there - 28295821 . Thanks!
