tju2
Apr 10, 2017Aspirant
Readynas 626x expansion
New Readynas 626x running 6.6.1. I started with 2 2tb drives in the default xraid config. I then added 4 4tb drives, so I now have two 2tb drives in slots 1,2, and the rest are 4tb drives. The xra...
tju2
Thanks for the reply! I did reboot, but I haven't looked at the logs. I'll go grab those and take a look. Thanks!
xiao123
Apr 10, 2017NETGEAR Expert
Can you download your logs and send those in (see the Sending Logs link in my sig)?
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
- tju2Apr 11, 2017Aspirant
Hey Xiao - I ended up opening a case and uploaded the logs there - 28295821 . Thanks!
- mdgm-ntgrApr 12, 2017NETGEAR Employee Retired
Looking at smart_history.log and disk_info.log it looks like one of your disks in your EDA500 is failing. The EDA500 volume was resyncing at the time you sent in the logs.
In the main chassis, the vertical expansion partition on sde (channel 4 counting from 0 to 5, so disk 5 counting from 1 to 6), i.e. partition 4 on sde, i.e. sde4 is marked as a spare. So the volume hasn't expanded.
It's possible to force it to use the new disk.- tju2Apr 12, 2017Aspirant
Hi - yes, I fixed the disk in the eda500. How do I force the issue on the mail chassis on disk 5? Should I pull it, wipe it, put it back?
Thanks again for your feeback.
