computim
Mar 11, 2020Luminary
REadyNas 628X Ticket escalated to LVL 3 with no response in nearly 3 days.
Purchased a 628X unit as an upgrade to my 626X readyNas. Swapped the 6 WDD RED PRo 6TB drives over to the 628X with no issues and validated everything came up and was operational. Began adding the ...
Mar 11, 2020Guru - Experienced User
computim wrote:
Noted that initially the 626X was raid 5 and the 628X showed raid 6 after attempting to add the 7th drive in X-Raid. Support indicated that was normal.
Yes, that is normal. The idea is that dual-redundancy is the best default option when you have > 6 disks in the array. You could have switched to flexraid and maintained RAID-5.
computim wrote:
Netgear support had me take all drives out and reboot and the unit booted up. Added single drives adn the unit booted till the 5th drive was added.
Just to clarify - the NAS failed to boot when you added the 6th drive?
Perhaps test drives 6 and 7 with Lifeguard while you are waiting for support.
- computimMar 11, 2020Luminary
Thank you Stephen for the raid options. I'm good with the raid 6 dual redundancy. I have tested all the drives with WDD tool and no issues were detected on any of the drives. The odd piece was when 4 drives were in the unit and booted raidar showed that the 3 of the drives were at 13TB capacity and full with the 4th drive having no volume associated. Not sure if that is normal for only 4 drives being present.
Happy to check anything I'm able too.
Tim
- StephenBMar 11, 2020Guru - Experienced User
The rule for single redundancy is "sum the drives and subtract the largest". 4x6TB should give you an 18 TB volume - which would be reported as ~14.5 TiB in the NAS. 3x6TB would be 12 TB (or ~10.9 TiB).
All drives should have been part of the volume - though it was already formatted, you'd probably need to reformat it in the NAS in order to add it.
Of course the volume also should have been empty - not full.
On the main issue - L3 is obviously engaged for a reason, and we likely don't have enough info here to know that that reason is. Sometimes there are issues with the backplane, or a bad PSU that can cause issues when you install all the disks.
If you are looking for something to try, then maybe do an install on a single disk, and then try it in each slot (power down, move the disk, power back up). That will help you see if all the bays are working.
Thanks Stephen. I will give that a go and try moving a spare drive along the bays.
This was a working volume in a 626X and I upgraded to the 628X. Moved the drives as directed per Netgear 1-6 to the new unit. Validated all was working with the 6 drives. Perrformed back up. Then proceeded to shutdown and add 7th drive. The unit booted and proceeded to add the drive to the volume. I got the volume is degraded message and saw the percentage complete. Everything was progressing just fine till Monday morning when the units admin page was not accessible and the raidar tool couldnt locate the unit. I finally did a hard power off as the front graceful power off method was not working. I then proceeded to reboot the unit and it will get to 99% and hang. If I remove all the drives the unit will boot up. If I place drive one by one up to 4 the unit will boot. Once I place the 5th drive in the unit goes to 99% and hangs.
Thank you in advance for any thoughts.
Tim
