computim
Mar 11, 2020Luminary
REadyNas 628X Ticket escalated to LVL 3 with no response in nearly 3 days.
Purchased a 628X unit as an upgrade to my 626X readyNas. Swapped the 6 WDD RED PRo 6TB drives over to the 628X with no issues and validated everything came up and was operational. Began adding the ...
Sandshark
Mar 11, 2020Sensei
I believe that this is because 5 of 7 RAID6 drives are enough for it to recognize there is a volume present and less than that is not, which would mean volume integrity is the issue. Unfortunately, you may have been premature in stopping the re-sync. I have seen (and reported, as have others) issues with the ReadyNAS becoming unresponsive during processes such as sync and scrub, including the readynasd process reaching 100% CPU usage. In many cases, it ultimately does complete the action, though it takes forever because there is so little throughput available. This has even occurred on a powerful rack-mount NAS (4 core Xeon and 8GB memory). Netgear is either unable to duplicate this or doesn't care to try.
Netgear support likely can repair your volume. Unfortunately, I do not know how to help you get them to give you that support.
computim
Mar 12, 2020Luminary
Sandshark - Unfortunately what you are sharing is most likely the case. Netgear support did login to my unit finally and they said the reshaping had to finish. However, after a few hours of monitoring the support tech said my volume must be corrupt from adding the 7th drive and they wouldn't be able to recover. I find it suspect that the reshaping had not finished and was inching along but due to the amount of time it was going to take they determined that a factory reset was a better option. Of course gave me the 3rd party data recovery options as well. The saving grace here is I took the back up prior to adding the 7th drive. If I"m going through the trouble of factory resetting my unit and reconfiguring in order to restore my back up I'm most likely finished with Netgear. In no way should adding a drive cause this much grief to a supposed "flexible system". In my opinion the amount of time wasted waiting for Netgear and the amount of time to reconfigure warrants my descision the Netgear simply doesn't care.
Thank you for you assistance and sharing of information.
Tim
