Derek02
Nov 16, 2021Aspirant
ReadyNAS admin page inacessible due to 'Secure Connection Failed'/'unsupported protocol'.
Readynas pro 4 cannot access admin page due to 'Secure Connection Failed'/'unsupported protocol'. (1) I bought this second hand and performed a factory reset. RNDP4000 RND-4A running firmware ...
Sandshark
Nov 17, 2021Sensei
It's likely a security setting or something in your antivirus. OS4.2.x uses older versions of protocols and all NAS must use a self-signed certificate. Given it affects all browsers, my guess would be AV.
Internet Explorer is still available in Win10, so you can try that, too.
Once you have access, I highly recommend you consider upgrading to OS6 before you start loading all your files to it (since the upgrade destroys the volume). The issues with outdated protocols are just going to get worse as time goes by and the work-arounds are removed. If your NASA has only the original 1GB of memory, you are going to want to upgrade that, too, to make sure you have enough for OS6, especially if you also plan to run any apps.
Derek02
Nov 24, 2021Aspirant
Thank you for the suggestions. I found an old laptop with an old version of Firefox, and was able to access the admin page. From there I performed the upgrade to OS6 as described elsewhere on the forum (the instructions were not entirely accurate/sufficient so some guessing was required). This was eventually successful, and the device now runs OS6 and its admin page is accessible in latest versions of Firefox (I have not tested the other browsers).
Thank you for the help.
