joeycatanese
Oct 13, 2017Follower
ReadyNAS Admin Page is Offline
New ReadyNAS unit. I have it booted up and on a LAN with a laptop for configuring. RAIDar 6.3.0 program shows the status as Healthy, Firmware 6.6.0, IP Address of 169.254.1.237, all four HDDs are sho...
Sandshark
Oct 15, 2017Sensei
Is the volume still shown as syncing in RAIDar? If so, that can cause glitches in the interface.
If not, then the NAS runs from the OS installed on the drives, not from flash, and it sounds like something may have gone wrong when it installed it on your drives. Try an OS re-install from the boot menu: /How-do-I-access-the-boot-menu-on-my-ReadyNAS-102-202-212-or-312. Since you haven't put any data on it yet, doing a complete factory reset from the same menu is another option, but it will have to re-sync your volume again.
- StephenBOct 15, 2017Guru - Experienced User
If you purchased this new, then you are entitled to free phone support - try my.netgear.com
