Turbogutten
Oct 30, 2018Aspirant
ReadyNas and Asus RT-AT3200 Router
My old router just died, and I bought a Asus RT-AC3200 router and updated it to latest firmware.
I hooked up my Netgear ReadyNas Duo to the new routers lan port and powered it on.
The...
Marc_V
Oct 31, 2018NETGEAR Employee Retired
Welcome to the Community!
Have you checked if there's any issue with the cable? or if the NIC LED indicator lights up? Do other devices get DHCP address from the router?
You may want to check with Asus' Support regarding settings.
Regards
