Turbogutten
Oct 30, 2018Aspirant
ReadyNas and Asus RT-AT3200 Router
My old router just died, and I bought a Asus RT-AC3200 router and updated it to latest firmware.
I hooked up my Netgear ReadyNas Duo to the new routers lan port and powered it on.
The...
Turbogutten
Nov 13, 2018Aspirant
UPDATE
I was not able to fix my problem trying all sugestions from Asus support, so I returned the Asus router and bought a new Netgear X6S router instead. And now I am really fustrated, because I have exactly the same problem using the new Netgear router.
When conecting through the router, the Nic Light is on both the router and the NAS, indicating that they are conected, but the NAS is not detected by the RaidAr and do not show up at the routers network map .
When conecting directly through my laptops Lan port RaidAr detects the NAS, and I can browse the NAS and and also log into and use the Frontwiev admin page.
The NAS network interface IPv4 is set up to "use value from a DHCP server", but even so it seems like it is not obtaining ip adress from the router, or if it is it will not connect to the router/network.
I also just tried a OS reinstall (but I am not quite sure if that went through since RAIDiator firmware is still 4.1.16 after reinstall).
What could possibly be wrong here ? Everything was working just fine before my old Netgear X4 router died.
Anyone ? ?
Nov 13, 2018Guru - Experienced User
It would be the same, since every time you install firmware the NAS also updates it's flash.
The OS reinstall will reset the admin password to netgear1, so watch out for that.
Are you seeing negotiation of a gigabit network?
If you are, I think the next step is to set a static IP address in the NAS, and see if that works when you connect the NAS to the router.
- TurboguttenNov 14, 2018Aspirant
Yes, I was aware of the password reset.
I tried to set static IP adress when troubleshooting and connecting to the Asus router, but that did not help either...... so I guess it will be the same with the X6S. And I never had to set a static ip on the NAS when it was connected to the Netgear X4. Just plugged the NAS in to the X4 and it received ip adress from the router and showed up immediately.
Not sure what You mean by "Are you seeing negotiation of a gigabit network?"
Is there any chance there is something permanently wrong with the NAS? If that is the case, I do not understand why I am able to find and browse the NAS when connecting directly through the laptop but not through the router ?
I hoped to avoid a factory reset of the NAS, as I will lose all settings and the 1,5 TB of data stored on the disks. I will then have to download all the data from my sky-backup solution and
set up the NAS share-roules again, and that will take ages......
- StephenBNov 14, 2018Guru - Experienced User
When you are directly connected to your PC, and browse to the admin UI, you should be able to see the speed of the ethernet link.
On a Duo v1, it would be on the network->interfaces screen. It should tell you 1 Gbit/full duplex.
I don't think there isn't anything wrong with the hardware, since you can access it via the direct connect.
Well, you could also get a USB drive, and offload the data when the NAS is directly connected to the PC. That will probably be much faster than restoring from the cloud.
Do you have a spare disk that you aren't using? You could try removing the Duo's drives (labeling them by slot), and do a factory install with only the spare disk installed. If that connects properly to your network, it rules out any hardware issue.
Thank You for fast replies, Stephen B. I really appreciate it!
Interface Screen on NAS do not say 1GB, it says online / 10mb / Full-duplex
I have now cleared up a 2TB external HD, re-formatted it and has started to copy the NAS content over to de ExHD. That will take som hours I see......
I do not have any spare 2TB disk to put in the NAS, but I have already done the procedure with removing one HD from slot restarting and then put it back and restaring, so the 2 HD's are syncronized and status says healty on both HD's so there should be nothing wrong with the HD's.
The thing that worries me most is if there is something wrong with the NAS hardware, but as You say, probably not since I can connect the NAS to my laptop.
Is there any chance there is a software "hang-up" that will be restored if factory reset ? Have You heared of this problem and solution before ?
I still hope there might be a solution without having to factory reset the NAS, but as I am now backing it up, I'm prepared for the worst. Hopefully the backup will proceed without any errors. I'll give You an update when I wake up in the morning and the backup should be complete!
