Turbogutten
Oct 30, 2018Aspirant
ReadyNas and Asus RT-AT3200 Router
My old router just died, and I bought a Asus RT-AC3200 router and updated it to latest firmware.
I hooked up my Netgear ReadyNas Duo to the new routers lan port and powered it on.
The...
Turbogutten
Nov 15, 2018Aspirant
NAS is now backed up to the external HD with now problems, but before doing a factory reset I think I will try to asign the NAS a static IP again.
The Netgear X6S Router DHCP ip assign is set to: Starting IP: 10.0.0.2 and Endig Ip: 10.0.0.254
I will the set static IP: 10.0.0.168 in the NAS and reserve this adress + NAS mac adress in the Router, and that should be it, or ? ?
Do I have do do some more settings in the router or NAS ?
bedlam1
Nov 15, 2018Prodigy
on the NAS I would set the NAS network card to "Use DHCP" and remove the static 10.0.0.168 entry, also Disable IPv6 and check your DNS server addresses are present
