jimoe1
Sep 21, 2011Aspirant
ReadyNAS appears dead (support case #16745150)
Our ReadyNas nv+ (I think that is right. I'm doing this from memory; I'm supposed to be on vacation.) has ceased operations. The initial symptom was failure to allow NFS mounts. It then refused to shu...
arjoseph1
Sep 22, 2011Tutor
I recommend that you contact support. Once you get a case #, please edit the subject of your post and add the case # at the end. Thanks.
