RPB123
Jun 06, 2020Aspirant
ReadyNas Audit Access Level
Hi All, In the audit settings for our ReadyNas 312, I see there is an option for Audit Access Level. If you tick the box what does this do compared to not having it ticked? Is write-only alre...
Marc_V
Jun 07, 2020NETGEAR Employee Retired
It seems the option is to specifically audit the access that is selected. Not ticking the box means all access levels will be present on the audit.
HTH
- SandsharkJun 09, 2020Sensei
Marc_V wrote:It seems the option is to specifically audit the access that is selected. Not ticking the box means all access levels will be present on the audit.
HTH
That is certainly not intuitive and needs to be re-thought. Assuming folks have read the manual (if it's even in there and they even know where to find an updated one detailing the new features) is not a good plan.
I collection of check boxes for each audit function, all on by default, would seem appropriate. That or radio buttons with the default option of "all".
