tony359
May 05, 2014Apprentice
ReadyNAS Business 6 crashed
Hi all, After some playing with the box and having fitted two brand new 4GB RED drives in it, today I started my first serious data moving. I have a failing HDD on another RAID I would like to repl...
May 08, 2014Guru - Experienced User
Are you just sending one large file, or is there a mix of files?
Are this step changes happening with reads or writes (or both)?
Also, are you past your disk issues?
