tony359
May 05, 2014Apprentice
ReadyNAS Business 6 crashed
Hi all, After some playing with the box and having fitted two brand new 4GB RED drives in it, today I started my first serious data moving. I have a failing HDD on another RAID I would like to repl...
May 09, 2014Guru - Experienced User
I don't think the REDs are the cause. I think Netgear support was giving you the normal "not on the HCL" story, and the support contact may have tossed in the "known to cause issue" for good measure.
The HCL story is very tiresome. If they can't keep the list of good drives up to date, at least they could create a list of drives that they know for sure won't work.
