Nasuser4
Nov 11, 2017Aspirant
ReadyNAS creating C message... what does it mean?
Hi,
I purchased a RN314 and was using it for about 6 months. Then one day it stopped working. I performed a USB recovery without success. So I took the 4 drives (X-RAID) and connected it to my old nv+. powered it up and it said Updating or Installing FW and then continued onto creating c ...with a % counter. Then I powered it down because i was affraid that it would wipe my drives.
Is it supposed to do that?
Should i have left it alone?
What does creating C... mean?
Did it wipe away my data?
Thanks
- SandsharkSensei
Although the older and newer systems use "XRAID", the file system is completely different. And while OS6.x warns you that your drives are not blank in case you wanted to retain data from them, earlier OS's did not. Yes, you likely wiped out all of your data. Yes, it's supposed to do that.
Your first mistake was not coming here or directly to Netgear support first for advise. Your second was doing a USB restore -- it is very unlikely that was what you needed. The third was assuming that you could move the drives between dissimilar hardware.
"Creating C" means it was formatting your drives, which would wipe out your data. A paid recovery service may be able to recover some of the data. I don't think Netgear will even try in this case.
- Nasuser4Aspirant
Thank you SandShark for the information.
Unfortunately, I did not know what I was doing..... and now I am just trying to get back my RN314 working again.
I am hoping that I turned off the unit fast enough to cause minimal loss of data. It was creating the C volume at about 2-4% when i unplugged it from the wall....
Eversince we had a poweroutage at the house, the current NAS was not booting up and was stuck on the booting ... status. I hooked up a display to it and it told me to insert a bootable disk. So I figured that i needed to reinstall the OS via the USB recovery tool. Maybe it got corrupt somehow during the power outage.
I tried various USB sticks, used the "usbrecovery.v2.0.R15-T3", and found a couple of them that gave me the "gpio_it87 unknown chip found 8721 revision4". I spent the better part of a day trying to get it to boot from the USB stick. I several FW versions, including the version that came with the unit (OS 6.4.2)
After that, I tried to enter the boot menu to do a OS reinstall. And was unable to enter the boot menu. I tried it with the drives in and out of the system. There seems to be no way for me to enter the boot menu......
Do you think that the motherboard, RAM, or flash failed? What can I do to recover the NAS?
Do you think that if i get the NAS working again or buy a new RN314 that I can recover the data by using the disks as is with the OS6.X firmware?
Thanks!
If you power up the NAS with no disks inserted, does it show a "no disks" status? If so, does RAIDar discover it on another PC?
When did you purchase the NAS? Are you the first owner, or is it used?
