Docwagner's avatar
Docwagner
ReadyNAS Data loss
Greetings:
I have two ReadyNAS 2120 1u devices running 4TB drives. One at my shop one at my home and I backup between them. I had a drive fail on one of the systems and fortunately I had a fresh spare drive. I hot swapped the drives and the system started resyncing. I let that run overnight expecting for it to be done today and when I logged in the 4 drives now display in red and the system says 0 data and wants me to define a new volume.  Did I just lose all my data and if so why?? If not how can I recover it. The other three drive were healthy.
Thanks for any help.
  • Just to be clear, I only removed one drive. I didn't power down the system and the other drives were "healthy"
    • Docwagner's avatar
      Docwagner
      Update,
      I reviewed the logs. Disk 3 was showing problems and that is the one I replaced. Disk 3 was noted to be in RESYNC mode then ONLINE. Then It went back to RESYNC. Then I see increasing ATA error count on disk 1. Disk 3 went back and forth from ONLINE to RESYNC 5 or 6 times. Disk 1 then showed change from ONLINE to FAILED.  followed by a Volume data is resynced then Volume data is dead. Then it shows where I performed a reboot.
      It looks like I had a drive failure and when That was rebuilding a second drive failed. I'm wondering if I replaced drive 1 with a new drive (on order) drive 3 may have resynced enough to recover data when I replace drive 1???
      • StephenB's avatar
        Docwagner wrote:
        Update,
        You could try powering down, putting back the original Disk 3, and removing the failed Disk 1.  Then try booting read-only, and see if the volume mounts.
ProSupport for Business
