dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
mdgm-ntgr
Aug 22, 2014NETGEAR Employee Retired
You will need lvm2
Sounds like your system may have been running RAIDiator 3 or earlier from what you've said.
If you put a spare disk (must not be from your array) and do a factory default and if it manages to complete booting what firmware is it running (don't update the firmware yet)?
Are your disks front loading or top loading?: http://www.readynas.com/forum/viewtopic.php?p=156408#p156408
