dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to US...
mdgm-ntgr
Jul 23, 2015NETGEAR Employee Retired
The steps for the Pro 6 are different to the steps for Sparc.
For the Pro 6 you need to do e.g.
# mdadm --assemble --scan # vgscan # vgchange -a y # mount /dev/c/c /mnt
You should check the health of the disks first and the state of the md arrays, particularly the one involving partition 3 or 5 (depending on when you last did a factory reset).
Recovering files that were not deleted should be possible.
As for deleted files that may be difficult or impossible.
lapince
Jul 23, 2015Tutor
The disks seems to be healthy as I'm totally able to use the NAS and to copy all the informations that were not deleted.
I think that nobody ever did a factory reset on this NAS (I've started to try to manage everything about 1 month ago).
My quest here is to find a way to bring back the file that were deleted (for exemple using foremost or any other tool).
