yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
yoh-dah
Jul 16, 2006Guide
jarrett_gorin wrote:
yoh-dah wrote: ReadyNAS Device Compatibility List can be found here: http://www.infrant.com/forum/viewtopic.php?t=66
I am using the ReadyNAS NV on my home network with a Linksys RV082 router/8-port switch/firewall and it works perfectly.
I just checked your compatible equippmentlist and saw that the Linksys RV082 is not listed (although several other Linksys models are). So I thought you may want to add this to your list.
Thanks, I'll add it on.
