yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
Skyline1
Dec 04, 2006Aspirant
Cool, I see you went with the Netgear GS105 after all. Are you able to run 1000/full duplex now?
Interestingly, I have my GS108 plugged into a Linksys WRT54G (10/100 + 802.11b/g). The NV+ and desktop (Intel PRO1000GT) are plugged into the GS108 running jumbo frames. However, I've also got a laptop over 802.11g on the WRT54G. Everything works fine with the jumbo frames enabled and all. Surprising. You might give it a try just to see what happens.
Note that you'll get better read performance without jumbo frames, so if writes don't matter as much to you, don't bother...
