yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
yoh-dah
Mar 16, 2007Guide
SteinyD wrote: I have two product compatibility questions for the NV+
1- Patriot 1GB SODIMM memory module model PSD21G6672S. Is this compatible with the NV+?
If it's not in the hardware compatibility list, then it'll be up to you to check it with the built-in memory test. Typically if it passes 3 times in succession, you're probably OK.
2- DLink DIR-655 Router/switch and DLink DGS-2208 Switch - any issues here with the NV+?
Thank you!
There hasn't been any report of incompatibility with the DIR-655, however, our lab did find slowness in 10/100 mode with the DGS-2208 (works fine in gigE though) -- this is noted in the HCL.
