yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
SteinyD
Mar 16, 2007Tutor
Thanks - hard to tell from the compatibility list when things were added. One of the locations of the list looked like it hadn't been updated since Q4 last year. So sometimes hard to determine if currently offered equipment is being tested or even considered.
As for the memory, are there any speeds of memory that you know won't work? This memory is 5300. The memory on the list looks like 3200.
Thanks for the info though ..
yoh-dah wrote:
SteinyD wrote: I have two product compatibility questions for the NV+
1- Patriot 1GB SODIMM memory module model PSD21G6672S. Is this compatible with the NV+?
If it's not in the hardware compatibility list, then it'll be up to you to check it with the built-in memory test. Typically if it passes 3 times in succession, you're probably OK.
2- DLink DIR-655 Router/switch and DLink DGS-2208 Switch - any issues here with the NV+?
Thank you!
There hasn't been any report of incompatibility with the DIR-655, however, our lab did find slowness in 10/100 mode with the DGS-2208 (works fine in gigE though) -- this is noted in the HCL.
