yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
SteinyD
Mar 16, 2007Tutor
thanks for the link to the info. I just decided to order the NV+ with 1gb memory from Aegis. I'll have to spend more time reading the wiki now ..
I was holding out ordering the NV+ until the vista issues were sorted out. I've decided with today's release of the add-on, that Infrant is committed to making it work. You guys have too long a track record to let your ardent customers down! I'm counting on you to make sure I didn't make a bad decision!!! :shock:
Reards,
David
Reards,
David
r2-d2 wrote:
SteinyD wrote: As for the memory, are there any speeds of memory that you know won't work? This memory is 5300. The memory on the list looks like 3200.
5300 is PC2-5300. We support only PC-xxxx. PC2-xxxx is using DDR2 technologies, and PC-xxxx is DDR.
If you havn't read, please also check Memory Spec in our FAQ on Wiki.
